Austin Seven - Late Model Differential Internal Oil Seal Conversion
When rebuilding late "D" type
differentials, the original felt oil seals, the associated felt holders, washers and
retaining clips can be replaced with a modern oil seal as shown above. In this case
Chicago Rawhide Number 8821 seals were used.
The new seals are pressed into
the axle housing without using the original felt seal holder.
Photographs and Description - Bruce White 2000
