Rear Engine Seal
The original felt seal can be replaced by a rear seal conversion flange using a standard oil seal. This flange is available at many Austin Seven Clubs and Austin Seven specialists. The flywheel boss is normally modified to provide a suitable surface for the new oil seal.
