Austin Seven Cast Iron Steering Box
Components of the late model Austin Seven Cast Iron steering box
(Click on the yellow dots for a close-up view)
This steering box is easy to use on Specials as the steering column is soft soldered into the actual cast iron box. Lengthening the column is straight forward.
Photograph by Bruce White
